[gdal-dev] GDAL slow to write GeoTIFF?
jramm jamessramm at gmail.com
Mon Apr 27 23:25:57 PDT 2015
By tiled do you mean split into N seperate TIFF files (in which case the
answer is no), or can a single TIFF contain a tiling scheme? If so, is this
some option I need to pass to the driver when creating the output?
View this message in context: http://osgeo-org.1560.x6.nabble.com/GDAL-slow-to-write-GeoTIFF-tp5203128p5203202.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
