[gdal-dev] Changing color of raster images based on their data values - gdal
Even Rouault even.rouault at spatialys.com
Tue Feb 3 00:43:54 PST 2015
Le mardi 03 février 2015 07:14:58, user_name a écrit :
> Let's say I have 1 band raster images with Gray Color Interpretation and I
> want to change their color based on their data values. Data values -1, will
> be Blue, -0.5 will be Light Blue, 0 will be Yellow, 0.5 will be Orange and
> 1 will be Red. If the data values are <-3000, I want to have that colored
> Black and if the data values are >3.402, that should be colored White .
> Will that be possible in gdal? One of the color ramp available in qgis is
> the RdYlBu. That is what I preferred to use.
> Thank You!
"gdaldem color-relief" is what you want. See http://gdal.org/gdaldem.html
Even
> http://osgeo-org.1560.x6.nabble.com/Changing-color-of-raster-images-based-
> on-their-data-values-gdal-tp5185138.html Sent from the GDAL - Dev mailing
> list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
http://www.spatialys.com
