[gdal-dev] Wrong number or type of arguments for overloaded function 'CoordinateTransformation_TransformPoint'
DeTracey, Brendan Brendan.DeTracey at dfo-mpo.gc.ca
Tue Feb 10 10:13:52 PST 2015
The should be on the path. (Very strange that the Anaconda installer dumped a copy in its root directory.)
C:\Users\DeTraceyB\AppData\Local\Continuum\Anaconda>echo %PATH%
C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files\MATLAB\R2012a\bin;C:\Program Files (x86)\MATLAB\R2010bSP1\bin;C:\Users\DeTraceyB\AppData\Local\Continuum\Anaconda;C:\Users\DeTraceyB\AppData\Local\Continuum\Anaconda\Scripts;
C:\Users\DeTraceyB\AppData\Local\Continuum\Anaconda>dir proj.*
 Volume in drive C is OSDisk
 Volume Serial Number is 7A59-3F7E
 Directory of C:\Users\DeTraceyB\AppData\Local\Continuum\Anaconda
06/02/2015  07:45 AM           369,152 proj.dll
06/02/2015  07:45 AM            19,456 proj.exe
               2 File(s)        388,608 bytes
               0 Dir(s)  76,317,147,136 bytes free
C:\Users\DeTraceyB\AppData\Local\Continuum\Anaconda>proj.exe
Rel. 4.8.0, 6 March 2012
usage: proj.exe [ -beEfiIlormsStTvVwW [args] ] [ +opts[=arg] ] [ files ]
I also tried adding to the script :
gdal.SetConfigOption('PROJSO', 'C:\Users\DeTraceyB\AppData\Local\Continuum\Anaconda\proj.dll')
This also did not work.
> -----Original Message-----
> From: Even Rouault [mailto:even.rouault at spatialys.com]
> Sent: February-10-15 11:55 AM
> To: gdal-dev at lists.osgeo.org
> Cc: DeTracey, Brendan
> Subject: Re: [gdal-dev] Wrong number or type of arguments for overloaded
> Le mardi 10 février 2015 16:27:54, DeTracey, Brendan a écrit :
> > Hi,
> > I am using the GDAL python bindings via Windows 64 bit Anaconda, but I
> > am getting an error when I try to run one of the GDAL sample scripts,
> > tolatlong.py e.g.
> > E:\parse_cis>python tolatlong.py 0 0 temp.tif Traceback (most recent
> > call last):
> >   File "tolatlong.py", line 106, in <module>
> >     (int, lat, height) = ct.TransformPoint(X, Y)
> >   File
> > "C:\Users\DeTraceyB\AppData\Local\Continuum\Anaconda\lib\site-packages
> > \osg eo\osr.py", line 757, in TransformPoint return
> > _osr.CoordinateTransformation_TransformPoint(self, *args)
> > NotImplementedError: Wrong number or type of arguments for overloaded
> > function 'CoordinateTransformation_TransformPoint'. Possible C/C++
> > prototypes are:
> >     OSRCoordinateTransformationShadow::TransformPoint(double [3])
> > [3],double,double,double)
> > When I google this error I find it might be related to GDAL not
> > finding Proj (https://github.com/avalentino/gsdview/issues/89). Could
> > someone please verify that this would be the source of this error? I
> > have installed Proj under Anaconda and am trying to rule out whether
> > it is a problem with Anaconda or GDAL.
> Yes, it seems very likely this is due to proj missing. Check that proj.dll is
> available in one of the paths in the PATH.
> > Thanks,
> > Brendan
> > gdal-dev mailing list
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
> Spatialys - Geospatial professional services http://www.spatialys.com
