[gdal-dev] Transparency mask (alpha band) in ECW
Jukka Rahkonen jukka.rahkonen at maanmittauslaitos.fi
Wed Jul 8 03:46:27 PDT 2015
Nodata values with lossy compression like JPEG, ECW, or JPEG2000 do not
really work. I noticed that newest ECW SDK versions (>= 4) have support for
using a transparency mask:
http://blog.hexagongeospatial.com/help-ecw-speckled-edges/
"Using the ECWJP2 SDK terminology, a transparency mask is implemented as an
opacity band called AllOpacity."
GDAL ECW driver does not have support for this. I wonder if it could be
doable and if I should make a feature request. I also wonder if GDAL can
decode ECW files which have transparency mask correctly.
-Jukka Rahkonen-
