[gdal-dev] Bindings and typemaps
Even Rouault even.rouault at spatialys.com
Mon Mar 9 06:31:59 PDT 2015
Le lundi 09 mars 2015 14:27:05, Ari Jolma a écrit :
> 09.03.2015, 11:18, Even Rouault kirjoitti:
> > Or if you prefer Git, you could fork https://github.com/OSGeo/gdal
> I did this fork and made the changes in my copy. Then made a pull
> request and now it says that the Travis CI build passed.
> But I assume Java etc. are not tested by Travis?
The Java, Perl and Python bindings are tested by Travis. See .travis.yml at
the root of the repository
I've just added in Vagrant the ability to build the Java and CSharp bindings,
as well as Perl and Python. It turns out that Swig 2.0.4 that comes with
Ubuntu 12.04 isn't compatible with the CSharp bindings. So the .cpp files are
generated by a manually compiled swig 1.3.40. But at runtime I get a linking
failure.
> Ari
http://www.spatialys.com
