[gdal-dev] OpenFileGDB, feature classes in feature dataset
Even Rouault even.rouault at spatialys.com
Sat Mar 14 20:08:57 PDT 2015
Armin,
I've committed a fix in http://trac.osgeo.org/gdal/ticket/5875 that should
hopefully fix your issue. There was a problem with the presence of non spatial
tables that could cause later tables not to be listed. This wasn't specifically
related to feature classes.
Even
> Hi Even
> thanks for the reply!
> The FGDB dataset where I discovered that has unfortunately some
> commercial IPR restrictions, so I cannot share it (and it in addition
> has some 800 MB...). I will try to create a test FGDB with a similar
> internal structure, I have to check if I can create an FGDB v9 format
> with recent ArcGIS versions.
> Armin
> On 03/10/2015 06:48 AM, Even Rouault wrote:
> > Selon Armin Burger <armin.burger at gmx.net>:
> >> Dear all
> >> I have a question regarding the OpenFileGDB driver in 1.11.2 release. It
> >> now lists also non-spatial tables as layers of an FGDB (as mentioned in
> >> the changelog). But it seems to not list any more layers that are
> >> "feature classes" under a parent "feature dataset" (that's how the
> >> relation is displayed in ArcGIS). This is at least the case for FGDB's
> >> in older v9 format. In GDAL version 1.11.0 these feature classes were
> >> still listed as layers.
> >> Is this a bug or an intended behavior?
> > Looks like an unfortunate side effect. could you open a ticket and attach
> such a
> > GDB or provide a link to it ?
> >> Best regards
> >> Armin
> >> _______________________________________________
> >> gdal-dev mailing list
> >> gdal-dev at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
