[gdal-dev] Ogrtindex: schema consistency check too strict?
Even Rouault even.rouault at spatialys.com
Tue Mar 17 08:52:28 PDT 2015
Jukka,
Accepting both Integer and Integer64 as the same could cause problems. For
example let's say you have a ogr tile index whose first dataset has a
"foo(Integer)" field and the second dataset is "foo(Integer64)". In
gml_types=auto mode, I believe that MapServer will use the schema of the first
dataset for the whole tiles, so you could have truncation of Integer64 values.
By the way, Integer64 bit support in MapServer is sitting in this pull request:
https://github.com/mapserver/mapserver/pull/5061
Even
> Hi,
> Probably because of work done for 64 bit integer support ogrtindex in now
> nagging that schemata of shapefiles with fields defined as Number(9.0) and
> Number(10.0) do not match. The first is reported as Integer and the latter
> as Integer64. However, that difference should not have any meaning for
> ogrtindex utility or Mapserver that is using the index file.
> For being able to create indexes for our data I have had to run orgtindex
> with -accept_different_schemas option which is all right otherwise but it
> accepts also all the meaningful differences which can make real harm for
> Mapserver.
> I think that Integer and Integer64 could be made to mean the same for
> ogrtindex but I am not sure if it could have some consequences.
> -Jukka Rahkonen-
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
http://www.spatialys.com
