[gdal-dev] ogr2ogr: Stuck trying to append lots of gml files to postgis tables
Stephen Woodbridge woodbri at swoodbridge.com
Sun Mar 22 13:33:56 PDT 2015
On 3/22/2015 3:32 PM, Even Rouault wrote:
> Le dimanche 22 mars 2015 20:18:12, Stephen Woodbridge a écrit :
>> Hi all,
>> I have a directory of gml files. I can load any of them into postgis
>> without a problem. What I'm having a problem with is appending each file
>> to the existing tables. I'm using : GDAL 1.10.1, released 2013/08/26
>> $ ogrinfo raw_itn/6360199_sn6103_2c7157.gz
>> Had to open data source read-only.
>> INFO: Open of `raw_itn/6360199_sn6103_2c7157.gz'
>>         using driver `GML' successful.
>> 1: Road (None)
>> 2: RoadLink (Line String)
>> 3: RoadNode (Point)
>> $ ogrinfo raw_itn/6360199_sn6101_2c5532.gz
>> INFO: Open of `raw_itn/6360199_sn6101_2c5532.gz'
>> 1: RoadLinkInformation (Point)
>> 2: Road (None)
>> 3: RoadLink (Line String)
>> 4: RoadNodeInformation (None)
>> 5: RoadNode (Point)
>> Here is want I am trying:
>> dropdb -U postgres -h localhost data_itn
>> createdb -U postgres -h localhost data_itn
>> psql -U postgres -h localhost data_itn -c "create extension postgis"
>> psql -U postgres -h localhost data_itn -c "create schema itn"
>> psql -U postgres -h localhost data_itn -c "alter database data_itn set
>> search_path to itn, public, pg_catalog"
>> # this loads fine
>> ogr2ogr -append -f PostgreSQL PG:"host=localhost user=postgres
>> dbname=data_itn" raw_itn/6360199_sn6101_2c5532.gz
>> # all successive tries to append to the existing tables fails
>> dbname=data_itn" raw_itn/6360199_sn6103_2c7157.gz
>> ERROR 1: Layer road already exists, CreateLayer failed.
>> Use the layer creation option OVERWRITE=YES to replace it.
>> ERROR 1: Terminating translation prematurely after failed
>> translation of layer Road (use -skipfailures to skip errors)
>> If I don't install extension postgis then there is no problem reported
>> and it appears to load all the data by appending the tables with the
>> geometry in a colum wkb_geometry::bytea.
>> How can I load the data into postgis. I have over 700 gml files to load.
> Defining PG_LIST_ALL_TABLES=YES as environment variable should solve this. By
> default non-spatial tables are not listed when opening a PG database, and
> ogr2ogr is confused as it doesn't see the existing table as existing, so it
> tries to recreate it. With trunk, ogr2ogr & the PG driver have been improved
> so that specifying  PG_LIST_ALL_TABLES=YES is not needed in that scenario.
> Wondering if we shouldn't list all tables (excluding system tables) by
> default...
Thank you this is a very helpful response. I saw the
PG_LIST_ALL_TABLES=YES in the documentation, but but never connect that
with this problem.
If there is not a huge downside to listing all tables I can't see that
it is a problem because it only happens once after a connection. Or
maybe it only needs to be done if -append is set.
Anyway, Thanks for the help with this.
-Steve
>> Thanks,
>>     -Steve
>> This email has been checked for viruses by Avast antivirus software.
>> http://www.avast.com
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
