[gdal-dev] NetCDF driver improvements (including groups support)
Joaquim Luis jluis at ualg.pt
Mon Mar 30 04:30:41 PDT 2015
> Thanks a lot for your advices, my changes are already separated in
> different local GIT commits, so I plan to deliver them >into separated
> patches/tickets (I already did it for change 7 related to ticket #5291).
Hi Julien,
Please note that I had to reopen #5291 because unfortunately your patch,
although it works, makes the reading unbearably slow.
Joaquim
> But I discussed with Even and before deliver the patches I have to add
> unit tests for each patch (especially for new >features), but
> unfortunately I don’t have a lot of free time to do this for the
> moment...
> Cheers,
> Julien
> De : Etienne Tourigny [mailto:etourigny.dev at gmail.com]Envoyé : lundi 30
> mars 2015 03:52
> À : Julien Demaria
> Cc : gdal-dev at lists.osgeo.org
> Objet : Re: [gdal-dev] NetCDF driver improvements (including groups
> support)
> Hi Julien
> These improvements look really great!
> Unfortunately I am on a long-term vacation and semi-retired from my GIS
> work. So I am sorry but I cannot really help on >testing and committing
> the work...
> That is why I did not respond sooner.
> As the last "official" netcdf maintainer I should at least give some
> comments.
> Perhaps Even can test the patches and commit them, or someone could step
> in as a new netcdf maintainer.
> If it is possible, It would be best to separate these improvements into
> a number of patches. In any case you should add your >patch(es) to a
> number of new gdal trac ticket(s) (or existing ticket if it fixes a
> bug).  I did significant improvements some time >ago and I understand
> that it is hard to separate these improvements in several patches, so I
> don't think it is absolutely >necessary to split them up - but it helps
> debugging any regressions. Especially the groups support, I/O
> improvements and >NASA products should have independent patches and
> tickets.
> Regarding 10) it would be best to maintain backwards compatibility, but
> if the issue is only with 1D dataset I don't think it >matters that much.
> Cheers,
> Etienne
> On Thu, Feb 5, 2015 at 11:10 PM, Julien Demaria
> <Julien.Demaria at acri-st.fr> wrote:
> Hi GDAL team,
> I've implemented several improvements to the NetCDF driver and I would
> like to provide them to the community.
> Main goal of the changes is to add full support of NetCDF-4 including
> groups.
> NetCDF-4 is the future format of ESA Sentinel-3 products (no groups) and
> NASA Ocean Color team is switching their L2/>L3 products to NetCDF-4
> with groups (VIIRS has already switched to the new format in December).
> With the changes NASA L2 products geolocation is automatically handled
> as geolocation arrays and can be reprojected using >gdalwarp.
> I validated with autotests that nothing is broken in tests netcdf.py
> (excepting test 13 but see my point 5), netcdf_cf.py and >hdf5.py, using
> NetCDF-3 and 4 libraries.
> I've also tested the new functionalities on various NetCDF-4 files.
> I think the only possible regression could be for marginal cases where a
> file was seen directly as a dataset and is now seen as >multiple
> subdatasets (for example if a file has only one var in the top group and
> has nested groups containing variables), but I >think this is not very
> common.
> For the moment I have all these changes in local GIT separated commits
> on the latest gdal-1.11 branch, let me know what >changes you want and
> how can I provide them.
> Changes :
> 1) Implement full support for NetCDF-4 groups on reading:
>    - explore recursively all nested groups to create the subdatasets list
>    - subdatasets in nested groups use the /group1/group2/.../groupn/var
> standard
>      NetCDF-4 convention, excepting for variables in the root group
> which do not
>      have a leading slash for backward compatibility
>    - when accessing a subdataset using NETCDF:$file:$path, the leading
> slash is optional
>    - global attributes of each nested group are also collected in the
> GDAL dataset
>      metadata, using the same convention
> /group1/group2/.../groupn/NC_GLOBAL#attr_name,
>      excepting for the root group which do not have a leading slash for
>    - when searching for a variable containing auxiliary information on
> the selected subdataset,
>      like coordinate variables or grid_mapping, we now also search in
> parent groups (using NCDFResolveVar).
>      I now this is something not specified at this time in the CF
> convention because CF does not know groups,
>      but it seems logical to me to support this: NetCDF-4 specifies that
> dimensions of a group are
>      shared to its nested groups, so associated coordinate variables
> could be defined as the same level of its
>      corresponding dimension.
>    - reference to coordinate variables using the "coordinates" attribute
> support now also absolute paths,
>      this allow for example to specify coordinate variables located
> outside the group of the selected variable
>      or its parents. Relative paths could be implemented if needed.
>      This feature is used to add support for new NASA Ocean Color L2
> products.
> 2) Implement full read/write support for new NetCDF4 types NC_UBYTE,
> NC_USHORT, NC_UINT and NC_STRING, >only if NETCDF_HAS_NC4 is defined
> (and only if format=NC4 for writing).
>    Support implemented for variables and attributes.
>    NC_STRING type is supported for reading (scalar and arrays)
> attributes and is used for writing only for array attributes >(scalar
> are still written as NC_CHAR).
>    If NETCDF_HAS_NC4 is not defined or format!=NC4, NC_STRING array
> attributes are written as a single NC_CHAR >string using the GDAL
> {v1,v2,...} convention.
>    Add missing support for NC_BYTE in CreateBandMetadata() and
> NC_BYTE/SHORT in NCDFPut1DVar().
> 3) Add support for new NASA Ocean Color L2 products and ESA Sentinel-3
> L1 or
>    L2 products which use the NetCDF-4 format (with groups for NASA, see
>    http://oceancolor.gsfc.nasa.gov/DOCS/FormatChange.html):
>    - NASA products: simulate a "coordinates" variable attribute to
> detect CF
>      geolocation arrays, and set bBottomUp to FALSE
>    - ESA products: set bBottomUp to FALSE and disable warning on missing
>      Conventions attribute
> 4) Fix bug #4554 with a more generic solution by disabling the
> installation of the HDF5 atexit() cleanup routine using >H5dont_atexit().
>    Previous fix was to call GDALExit() (for the moment only defined
> gdalwarp.cpp) at the end of every program, which is >more painful.
> 5) Fix implementation of GetScale/Offset to not always return
> pbSuccess=TRUE.
>    Fix CopyMetadata to handle bands with only scale or offset.
>    ==> WARNING this commit breaks the autotest netcdf_13 (check for
> scale/offset = 1.0/0.0 if no scale or offset is >available), but for me
> it is not logical to return always pbSuccess=TRUE
> 6) Optimize IReadBlock() and CheckData() handling of partial blocks in
> the x axis by re-using the GDAL block buffer instead >of allocating a
> new temporary buffer for each block.
> 7) Force block size to 1 scanline for bottom-up datasets if nBlockYSize
> != 1 instead of raising a fatal error
>    ==> Solve a recent problem raised on the mailing list
> 8) Implement Get/SetUnitType using the standard "units" NetCDF attribute
> 9) Change default block size to 256x256 instead of scanline (only affect
> file without NetCDF chunking)
>    ==> because I think this is better for a random access to the data,
> but I'm not sure if the community want this change which >could impact
> performances
> 10) I've also implemented for my needs support for 1D variables by
> simulating 2D datasets with only one row (dimensionless >variables are
> not supported for the moment),
>       but this breaks backward compatibility because files containing
> only one variable and associated 1D coordinate variables >are now seen
> as multiple sub datasets...
>       and maybe this is not the goal of GDAL to give access to
> not-2D-raster variables (but sometimes it's useful ;-) )
> Thanks for GDAL!
> Julien
> gdal-dev mailing list
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150330/bc2a7e14/attachment.html>
