[gdal-dev] create GeospatialPDF using Python
Luca Delucchi lucadeluge at gmail.com
Tue May 12 00:19:59 PDT 2015
On 12 May 2015 at 00:27, Jukka Rahkonen
<jukka.rahkonen at maanmittauslaitos.fi> wrote:
> Luca Delucchi <lucadeluge <at> gmail.com> writes:
>> On 21 April 2015 at 11:00, Jukka Rahkonen
>> <jukka.rahkonen <at> maanmittauslaitos.fi> wrote:
>> > Hi,
>> Hi,
>> > I would say "Yes, it may be a bug". If you would like to get a better answer
>> > you should show us a simple way to reproduce. In this case I think that an
>> > OGR_STYLE string with your gdal_translate command would be the minimum but
>> > even nicer would be to get also the raster and your faulty result file to
>> > compare with.
>> Sorry the late answer, data are here [0] (about 30MB) and this is the
>> gdal_translate -of PDF raster.pdf combine.pdf -co OGR_DATASOURCE=vector.pdf
> Hi,
> If you test vector.pdf with ogrinfo it shows attributes
> OGRFeature(TR):14
>   id (Integer) = 16
>   Class (String) = MANUFATTI
>   cls (Integer) = 4
> I would try to save the same OGR_STYLE string that you have used for styling
> the polygons also as an attribute into PDF. Perhaps then GDAL could read the
> style back and transfer it to the other PDF.
Ok, I'll try and let you know
> -Jukka Rahkonen-
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
