[gdal-dev] gdaladdo problems with compression
Even Rouault even.rouault at spatialys.com
Mon Sep 14 02:56:04 PDT 2015
Le lundi 14 septembre 2015 11:46:45, Stefan Ziegler a écrit :
> Hi
> we are facing problems with the compression of the overviews we are adding
> with gdaladdo. The filesize does not differ whether we are using
> compression parameters or not. The filesize of the input raster is approx.
> 100 mb. The following both commands resulting in an identical filesize of
> approx. 140mb.
> gdaladdo -r average  591252_12_5cm.tif 2 4 8 16 32
> gdaladdo -r average --config COMPRESS_OVERVIEW JPEG --config
> PHOTOMETRIC_OVERVIEW YCBCR --config INTERLEAVE_OVERVIEW PIXEL
Stefan,
The config options are only used for external overviews (-ro flag). For internal
overviews, the same compression scheme as the full resolution image is used.
In theory they could also use a different compression scheme, but this isn't
currently implemented.
Even
> The input raster is tiled and compressed with deflate (and predictor=2)
> I would expect that the latter one would be smaller. Did we misunderstand
> something? Or do we use the parameters the wrong way?
> GDAL 1.11.2 and dev.
> regards
> Stefan
http://www.spatialys.com
