[gdal-dev] GDAL 2.1 Beta and GRASS 7.0.4
Even Rouault even.rouault at spatialys.com
Mon Apr 11 01:00:59 PDT 2016
Le lundi 11 avril 2016 09:13:06, Blumentrath, Stefan a écrit :
> Hi again,
> One more question:
> Before I installed GDAL 2.1 with GRASS 7.0.4svn support I ran GDAL 1.11
> compiled against GRASS 7.0.2.
> Now I get on every GDAL command this: error message:
> ERROR 1: libgrass_gis.7.0.2svn.so: cannot open shared object file: No such
> file or directory ERROR 1: libgrass_gis.7.0.2svn.so: cannot open shared
> object file: No such file or directory ERROR 1:
> libgrass_raster.7.0.2svn.so: cannot open shared object file: No such file
> or directory ERROR 1: libgrass_raster.7.0.2svn.so: cannot open shared
> object file: No such file or directory Warning 1: GRASS warning: GISBASE
> environment variable was not set, using: /usr/local/grass-7.0.4svn
> Driver: GRASS/GRASS Rasters (5.7+)
If you had GRASS support as a plugin of GDAL 1.11 installed in
/usr/local/share/gdalplugins, I guess this messages comes from the plugin when
GDAL 2.1 tries to load it.
http://www.spatialys.com
