[gdal-dev] reading multidimension netCDF using gdal
Giuseppe Amatulli giuseppe.amatulli at gmail.com
Thu Apr 14 14:33:32 PDT 2016
I'm trying to merge this 3 tif files having different pixel resolution in
one single file.
wget https://dl.dropboxusercontent.com/u/29337496/nc/tpi_max_km10.tif
wget https://dl.dropboxusercontent.com/u/29337496/nc/tpi_max_km50.tif
wget https://dl.dropboxusercontent.com/u/29337496/nc/tpi_max_km100.tif
According to my understanding the only raster format  that support
different pixel resolution are  HDF & NetCDF.
I opt for the NetCDF format and I wrote the following script that, change
the format from tif to nc, change some internal parameters using NCO and in
the end merge (grupping -  in NCO terminology) the *.nc together.
longname=Topographic_position_index
VAR=tpi_max_km
for km  in 10 50 100 ;  do
    if [ $km -eq 10  ] ; then b=1 ; fi
    if [ $km -eq 50  ] ; then b=2 ; fi
    if [ $km -eq 100 ] ; then b=3 ; fi
    gdal_translate -of netCDF    -co ZLEVEL=9  -co  COMPRESS=DEFLATE  -co
FORMAT=NC4C   $VAR$km.tif   $VAR$km.nc
### Change some parameters
    ncatted  -O -a long_name,Band1,o,c,${longname}        $VAR$km.nc -h
    ncatted  -O -a long_name,lon,o,c,Longitude            $VAR$km.nc -h
    ncatted  -O -a long_name,lat,o,c,Latitude             $VAR$km.nc -h
    ncatted  -O -a _FillValue,Band1,o,i,-9999        $VAR$km.nc -h
    ncrename -v Band1,${VAR}${km}   $VAR$km.nc -h
done
# create multi-dimension nc
ncecat --gag  tpi_max_km10.nc tpi_max_km50.nc tpi_max_km100.nc    out.nc
The problem comes when I want read the output using gdal.
gdalinfo out.nc
Warning 1: out.nc is a netCDF file, but not in GMT configuration.
gdalinfo failed - unable to open 'out.nc'.
Is gdal 1.10.0 able to read multidimensional NetCDF ?
Can I do "ncecat --gag" (grouping) operation using gdal?
Any ideas?
Thanks
Giuseppe Amatulli, Ph.D.
Department of Ecology and Evolutionary Biology, Yale University.
Jetz Lab, OML Room 405
P.O. Box 208106
165 PROSPECT ST
New Haven, CT 06520-8106
Teaching: spatial-ecology.net
Work:  http://sbsc.yale.edu/giuseppe-amatulli
<http://www.spatial-ecology.net>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160414/26a50248/attachment.html>
