[gdal-dev] Motion: Promote 2.1.0RC3 for release
Sean Gillies sean at mapbox.com
Mon Apr 25 08:45:20 PDT 2016
On Mon, Apr 25, 2016 at 9:25 AM, Even Rouault <even.rouault at spatialys.com>
wrote:
> Hi Sean,
> > I see something that looks like a regression between the beta and rc3 in
> my
> > Rasterio CI
> >   https://travis-ci.org/mapbox/rasterio/jobs/125120910#L1429
> > That test was passing with the beta release. Any chance of holding the
> > release up for 60 minutes while I double check that I'm just not building
> > 2.1.0 wrong on Travis?
> Sure, take the needed time.
> Is this test about catching GDAL debug messages ? There was a change in
> GDAL
> logging just before beta1 related to that (and normally with little impact
> in
> the default behaviour), so if that worked with beta1, no reason that
> doesn't
> work anymore. I'm short of idea otherwise.
Can you point me to the commit changing the logging?
I might be confused about whether I'm comparing rc3 behavior to beta1 or an
earlier snapshot. There's definitely a change since April 1's dev
prerelease.
Sean Gillies
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160425/fe5ee4b1/attachment.html>
