[gdal-dev] Probably bug with HDF4-EOS driver
Anton Korosov anton.korosov at nersc.no
Wed Aug 10 02:13:49 PDT 2016
Dear GDAL developers,
I was trying to access MODIS L1 data available e.g. here:
ftp://ladsweb.nascom.nasa.gov/allData/6/MYD02HKM/
and since GDAL version (2.1.0) the values of Ground Control Points are
completely wrong. GCPPixel and GCPLine are twice larger than should be
and GCPX, GCPY are just insane.
gdalinfo
HDF4_EOS:EOS_SWATH:"MYD02HKM.A2016148.1050.006.2016149162607.hdf":MODIS_SWATH_Type_L1B:EV_500_RefSB
Driver: HDF4Image/HDF4 Dataset
Files: MYD02HKM.A2016148.1050.006.2016149162607.hdf
Size is 2708, 4060
Coordinate System is `'
GCP Projection =
GEOGCS["WGS 84",
     DATUM["WGS_1984",
         SPHEROID["WGS 84",6378137,298.257223563,
             AUTHORITY["EPSG","7030"]],
         AUTHORITY["EPSG","6326"]],
     PRIMEM["Greenwich",0,
         AUTHORITY["EPSG","8901"]],
     UNIT["degree",0.0174532925199433,
         AUTHORITY["EPSG","9122"]],
     AUTHORITY["EPSG","4326"]]
GCP[  0]: Id=, Info=
           (0.5,0.5) -> (170569270408.57,2706131931253.88,0)
GCP[  1]: Id=, Info=
           (246.5,0.5) -> (33576161415.8712,2701109252213.01,0)
GCP[  2]: Id=, Info=
           (492.5,0.5) -> (14008281153.2792,2628614901860.17,0)
GCP[  3]: Id=, Info=
           (738.5,0.5) -> (5961274399.40133,2544871428176.69,0)
GCP[  4]: Id=, Info=
           (984.5,0.5) -> (2034123015.4764,2457627807804.38,0)
GCP[  5]: Id=, Info=
           (1230.5,0.5) -> (855102595.575362,2365791424551.01,0)
Earlier version (2.0.2) reports correct values
gdalinfo
HDF4_EOS:EOS_SWATH:"/home/antonk/py/nansat-lectures/notebooks/examples/nansat-paper/MYD02HKM.A2011229.1005.005.2011230152517.hdf":MODIS_SWATH_Type_L1B:EV_500_RefSB
Files: none associated
Size is 2708, 4060
GCP Projection =
GEOGCS["WGS 84",
     DATUM["WGS_1984",
         TOWGS84[0,0,0,0,0,0,0],
         AUTHORITY["EPSG","9108"]],
GCP[  0]: Id=, Info=
           (0.5,0.5) -> (59.6357002258301,61.7213020324707,0)
GCP[  1]: Id=, Info=
           (246.5,0.5) -> (51.7233047485352,61.6709632873535,0)
GCP[  2]: Id=, Info=
           (492.5,0.5) -> (47.139404296875,61.4298629760742,0)
I was installing GDAL using conda either the standard channel (e.g.:
conda install gdal=2.1.0) or the conda-forge one (e.g. conda install
gdal=2.0.2 -c conda-forge). The results are the same.
Can you please confirm that this is reproducible without conda and I can
submit a ticket?
Regards!
Anton
Nansen Environmental and Remote Sensing Center
Address: Thormøhlens gate 47, NO-5006 Bergen, NORWAY
Website: www.nersc.no, Email: post at nersc.no
Work: +47 55 20 58 00, Fax: +47 55 20 58 01
