[gdal-dev] [GDAL Python] Save a dataset to an in memory Python Bytes object
domlysz domlysz at gmail.com
Wed Aug 10 06:35:19 PDT 2016
Hi all,
I'm trying to use GDAL Python API to save a Numpy array directly to a Python
bytes object in PNG format. Then, bytes data will be pushed as BLOB in a
SQlite database, so I want to avoid using an intermediate file on disk.
I wish to reproduce something like this snippet with PIL/PILLOW:
b = io.BytesIO()
img = Image.fromarray(data)
img.save(b, format='PNG')
data = b.getvalue() #convert bytesio to bytes
For now I tried to write my Numpy array in a memory dataset:
img_h, img_w, nbBands = data.shape
mem = gdal.GetDriverByName('MEM').Create('', img_w, img_h, nbBands,
gdal.GDT_Byte)
for bandIdx in range(nbBands):
	bandArray = data[:,:,bandIdx]
	mem.GetRasterBand(bandIdx+1).WriteArray(bandArray)
and then save the dataset to a bytes object using the CreateCopy method:
b = io.BytesIO()
out = gdal.GetDriverByName('PNG').CreateCopy(b, mem)
But CreateCopy only accept a valid string path not a bytes object.
I know it's possible to read a bytes stream through a virtual memory file
req = urllib.request.Request(url)
handle = urllib.request.urlopen(req)
data = handle.read()
vsipath = '/vsimem/img'
gdal.FileFromMemBuffer(vsipath, data)
ds = gdal.Open(vsipath)
But I did not find any information on how to do the inverse of this. It's
seems the ReadRaster method return bytes data but if I try to reopen this
output with PIL, it can't recognize the image format.
Any help on this will be very appreciate.
Thanks in advance.
Dominique
View this message in context: http://osgeo-org.1560.x6.nabble.com/GDAL-Python-Save-a-dataset-to-an-in-memory-Python-Bytes-object-tp5280254.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
