[gdal-dev] Convert precipitation accumulations from HDF5 to GeoTiff
Paul Meems bontepaarden at gmail.com
Tue Dec 13 04:46:17 PST 2016
Thanks Rutger,
You are completely right. I assumed the coordinates were in the same
projection as the project string.
Menno van Scheers replied me directly and suggested I should use 0.0,
-3650.000, 800.000, -4415.000 as ullr coordinates.
I tried it and now the GeoTiff is where I expect it to be.
Paul
*Paul Meems *
Release manager, configuration manager
and forum moderator of MapWindow GIS.
www.mapwindow.org
Owner of MapWindow.nl - Support for
Dutch speaking users.
www.mapwindow.nl
*The MapWindow GIS project has moved to GitHub
<https://github.com/MapWindow>!*
Download the latest MapWinGIS mapping engine.
<https://github.com/MapWindow/MapWinGIS/releases>
Download the latest MapWindow 5 open source desktop application.
<https://github.com/MapWindow/MapWindow5/releases>
2016-12-13 11:29 GMT+01:00 Rutger <kassies at gmail.com>:
> Hey Paul,
> If you assign the RD projection with 'a_srs', you should also assign the
> 'ullr' coordinates in that same projection, not in lat/lon degrees like you
> do now.
> Regards,
> Rutger
> View this message in context: http://osgeo-org.1560.x6.
> nabble.com/gdal-dev-Convert-precipitation-accumulations-
> from-HDF5-to-GeoTiff-tp5299661p5299666.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20161213/0ac8beea/attachment.html>
