[gdal-dev] osmconf.ini
Jukka Rahkonen jukka.rahkonen at maanmittauslaitos.fi
Fri Feb 19 04:20:25 PST 2016
Frank Broniewski <frank.broniewski <at> gmail.com> writes:
> Hi,
> I am having some trouble understanding, when - or how - multilinestrings
are imported into PostGIS. I am interested in hiking routes from
OpenStreetMap and I try to figure out how I can load them correctly into
PostGIS. The corresponding OSM Wiki page would be this:
http://wiki.openstreetmap.org/wiki/Hiking ,especially the part called
"Tagging walking and hiking Route Networks". There should be more hiking
routes as relations in my test region e.g.
http://www.openstreetmap.org/relation/2827792 is missing. It is not quite
clear to my how ogr2ogr decides what kind of data is put into which table.
> So, what do I have to do to import this relation into the multilinestrings
table? Please find my osmconf.ini attached to this email for further reference.
> BTW, this is with GDAL 1.11.3, released 2015/09/16, on Windows 10 provided
by OSGeo4W.
> Many thanks,
> Frank
> Attachment (osmconf.ini): application/octet-stream, 3757 bytes
By quick look your osmconf.ini is OK, there is "route" along the
multilinestring attributes and data contain tag "route=hiking". Could you
put a complete, hopefully small sample of OSM data with hiking routes that
could be used for testing somewhere for downloading?
-Jukka Rahkonen-
