[gdal-dev] Is there Any limitation in name of the file name in CreateDataSource in Filegeodb
Even Rouault even.rouault at spatialys.com
Wed Jan 6 01:57:18 PST 2016
Le mardi 05 janvier 2016 20:17:34, Gane R a écrit :
> It is weired, when I call CreateDataSource as I had discussed earlier, I
> send a large filename with absoluted path to it. I causes a crash at when
> called from java via jni
> Is there any limitation in the name of the filename when passing to
> CreateDataSource call.
> poDrv->CreateDataSource <= example
You could try with ogr2ogr first.
http://www.spatialys.com
