[gdal-dev] Intersection of two Layers
Ari Jolma ari.jolma at gmail.com
Sun Jan 24 05:35:22 PST 2016
24.01.2016, 14:49, Kai Mühlbauer kirjoitti:
> Am 23.01.2016 um 11:29 schrieb Ari Jolma:
>> I've committed the enhancement to the trunk.
> Great!
>> The new options are USE_PREPARED_GEOMETRIES, which defaults to YES, and
>> PRETEST_CONTAINMENT (note the change in this key), which defaults to NO.
> Compiled and tested here, works with my current python code. It took
> me a while to figure that the key is actually PRETEST_CONTAINS.
Auts. Fixed in r33140. "Containment" is linguistically better in my opinion.
> Thanks a lot for implementing this enhancement in such a short time!
> Do you happen to know in which forthcoming release this changes will
> be present?
2.1, which will be released in April probably
http://osgeo-org.1560.x6.nabble.com/gdal-dev-GDAL-2-1-release-plans-td5245559.html
Ari
> Cheers,
> Kai
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
