[gdal-dev] Compiling GDAL with Visual Studio 2015
Christopher McGeorge cmcgeorge at surgeforward.com
Fri Jul 1 20:01:44 PDT 2016
Thank you for your help, Even.  Yes, I tried cleaning before rebuilding and even re-downloading the original source code.
Thank you for your posting on AppVeyour.  To verify, you simply downloaded the following file:
    release-1800-x64-gdal-mapserver-src.zip
unzipped, changed to the "gdal" folder, uncommented out the following line in "nmake.opt":
    #WIN64=YES
and ran the following command:
    nmake -f makefile.vc MSVC_VER=1900 WIN64=yes
Thank you,
Chris
-----Original Message-----
From: Even Rouault [mailto:even.rouault at spatialys.com]
Sent: Friday, July 01, 2016 6:23 PM
To: Christopher McGeorge <cmcgeorge at surgeforward.com>; gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] Compiling GDAL with Visual Studio 2015
Le samedi 02 juillet 2016 02:13:03, vous avez écrit :
> Hi, Even.  Thank you for your response.  Yes, I uncommented out this
> line in the nmake.opt file, and I used the "WIN64=yes" nmake
> command-line argument.
And MSVC_VER=1900 ?
Make sure to clean before rebuilding if you change options
Here's a successful build on AppVeyour in case that helps:
https://ci.appveyor.com/project/rouault/gdal-coverage/build/1.0.5162/job/7np9al6m0uriphp1
> Thank you,
> Chris
> Sent: Friday, July 01, 2016 6:10 PM
> To: gdal-dev at lists.osgeo.org
> Cc: Christopher McGeorge <cmcgeorge at surgeforward.com>
> Le samedi 02 juillet 2016 01:57:10, Christopher McGeorge a écrit :
> > Hi.  Has anyone been able to build 64-bit GDAL 2.1 using Visual
> > Studio 2015? I keep getting the following errors that I have not
> > been able to
> > resolve:
> Did you define WIN64=YES in nmake.opt/nmake.local ?
> > LINK : error LNK2001: unresolved external symbol
> > OCTNewCoordinateTransformation
> > LINK : error LNK2001: unresolved external symbol GDALDitherRGB2PCT
> > GDALComputeMedianCutPCT
> > LINK : error LNK2001: unresolved external symbol GDALReprojectImage
> > LINK : error LNK2001: unresolved external symbol GDALSimpleImageWarp
> > LINK : error LNK2001: unresolved external symbol OGRRegisterAll
> > LINK : error LNK2001: unresolved external symbol OGR_G_GetPointCount
> > OPTGetProjectionMethods
> > LINK : error LNK2001: unresolved external symbol OSRValidate
> > gdal201.dll : fatal error LNK1120: 9 unresolved externals
> > Thank you,
> > Chris
> > This email has been checked for viruses by Avast antivirus software.
> > https://www.avast.com/antivirus
> Spatialys - Geospatial professional services http://www.spatialys.com
