[gdal-dev] Compiling GDAL with Visual Studio 2015
James Ramm jamessramm at gmail.com
Sat Jul 2 00:14:07 PDT 2016
I'm am compiling successfully with vs 2015, both the library and python 3
bindings. The only thing I would add is to  make sure you run vcvarsall.bat
amd64. I'm building from trunk.
On 2 Jul 2016 4:02 a.m., "Christopher McGeorge" <cmcgeorge at surgeforward.com>
wrote:
> Thank you for your help, Even.  Yes, I tried cleaning before rebuilding
> and even re-downloading the original source code.
> Thank you for your posting on AppVeyour.  To verify, you simply downloaded
> the following file:
>     release-1800-x64-gdal-mapserver-src.zip
> unzipped, changed to the "gdal" folder, uncommented out the following line
> in "nmake.opt":
>     #WIN64=YES
> and ran the following command:
>     nmake -f makefile.vc MSVC_VER=1900 WIN64=yes
> Thank you,
> Chris
> -----Original Message-----
> From: Even Rouault [mailto:even.rouault at spatialys.com]
> Sent: Friday, July 01, 2016 6:23 PM
> To: Christopher McGeorge <cmcgeorge at surgeforward.com>;
> gdal-dev at lists.osgeo.org
> Subject: Re: [gdal-dev] Compiling GDAL with Visual Studio 2015
> Le samedi 02 juillet 2016 02:13:03, vous avez écrit :
> > Hi, Even.  Thank you for your response.  Yes, I uncommented out this
> > line in the nmake.opt file, and I used the "WIN64=yes" nmake
> > command-line argument.
> And MSVC_VER=1900 ?
> Make sure to clean before rebuilding if you change options
> Here's a successful build on AppVeyour in case that helps:
> https://ci.appveyor.com/project/rouault/gdal-coverage/build/1.0.5162/job/7np9al6m0uriphp1
> > Thank you,
> > Chris
> > Sent: Friday, July 01, 2016 6:10 PM
> > To: gdal-dev at lists.osgeo.org
> > Cc: Christopher McGeorge <cmcgeorge at surgeforward.com>
> > Le samedi 02 juillet 2016 01:57:10, Christopher McGeorge a écrit :
> > > Hi.  Has anyone been able to build 64-bit GDAL 2.1 using Visual
> > > Studio 2015? I keep getting the following errors that I have not
> > > been able to
> > > resolve:
> > Did you define WIN64=YES in nmake.opt/nmake.local ?
> > > LINK : error LNK2001: unresolved external symbol
> > > OCTNewCoordinateTransformation
> > > LINK : error LNK2001: unresolved external symbol GDALDitherRGB2PCT
> > > GDALComputeMedianCutPCT
> > > LINK : error LNK2001: unresolved external symbol GDALReprojectImage
> > > LINK : error LNK2001: unresolved external symbol GDALSimpleImageWarp
> > > LINK : error LNK2001: unresolved external symbol OGRRegisterAll
> > > LINK : error LNK2001: unresolved external symbol OGR_G_GetPointCount
> > > OPTGetProjectionMethods
> > > LINK : error LNK2001: unresolved external symbol OSRValidate
> > > gdal201.dll : fatal error LNK1120: 9 unresolved externals
> > > Thank you,
> > > Chris
> > > This email has been checked for viruses by Avast antivirus software.
> > > https://www.avast.com/antivirus
> > Spatialys - Geospatial professional services http://www.spatialys.com
> gdal-dev mailing list
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160702/a021b06a/attachment.html>
