[gdal-dev] geospatialPDF DPI and EXTRA_IMAGES
Luca Delucchi lucadeluge at gmail.com
Mon Jun 6 07:06:01 PDT 2016
On 26 May 2016 at 17:23, Even Rouault <even.rouault at spatialys.com> wrote:
> Ah ok, so you create a vector dataset then ?
it could be both
> Here's the relevant code in pdfwritabledataset.cpp:
>     double dfRatio = (sGlobalExtent.MaxY - sGlobalExtent.MinY) /
> (sGlobalExtent.MaxX - sGlobalExtent.MinX);
>     int nWidth, nHeight;
>     if (dfRatio < 1)
>         nWidth = 1024;
>         nHeight = static_cast<int>(nWidth * dfRatio);
>     else
>         nHeight = 1024;
>         nWidth = static_cast<int>(nHeight / dfRatio);
> where sGlobalExtent is the georeferenced extent of the vectors added in the
> PDF vector layer.
thanks a lot, I was able to fix both raster and vector
> Even
ciao
Luca
www.lucadelu.org
