[gdal-dev] Question on writing a GTiff using python
Even Rouault even.rouault at spatialys.com
Sat Jun 18 10:52:07 PDT 2016
Le samedi 18 juin 2016 19:01:26, Stephen Woodbridge a écrit :
> Hi all,
> I'm writing a GTiff using GDAL/Python and it is mostly working. The
> source data is coming from a NETCDF file that is georeferenced in
> Longitude from 74.1600037 to 434.160 degrees
> If I use this I get:
> Size is 4500, 1782
> Coordinate System is:
> GEOGCS["WGS 84",
>      DATUM["WGS_1984",
>          SPHEROID["WGS 84",6378137,298.257223563,
>              AUTHORITY["EPSG","7030"]],
>          AUTHORITY["EPSG","6326"]],
>      PRIMEM["Greenwich",0],
>      UNIT["degree",0.0174532925199433],
>      AUTHORITY["EPSG","4326"]]
> Origin = (74.160003662109375,46.987300872802734)
> Pixel Size = (0.079999959309896,0.079999959309896)
> Corner Coordinates:
> Upper Left  (  74.1600037,  46.9873009) ( 74d 9'36.01"E, 46d59'14.28"N)
> Lower Left  (      74.160,     189.547) ( 74d 9'36.01"E,189d32'50.02"N)
> Upper Right (     434.160,      46.987) (Invalid angle, 46d59'14.28"N)
> Lower Right (     434.160,     189.547) (Invalid angle,189d32'50.02"N)
> Center      (     254.160,     118.267) (254d 9'35.68"E,118d16' 2.15"N)
> Looks like I also need to flip the Y axis, but ignore that for the moment.
You can perhaps try the GDAL_NETCDF_BOTTOMUP=YES/NO configuration option.
> Do I need to reorganize the pixels to be in the range of -180 to 180?
Not necessarily. GeoTIFF will accept any georeferencing. The choice of
reorganizing the pixels or not depends on the expectations of the
people/software using your GeoTIFF.
> What is the best way t do this?
> I can probably slice and splice the numpy array for each row as I copy
> it. Other options?
That's a reasonable option.
> Thanks,
>    -Steve
> This email has been checked for viruses by Avast antivirus software.
> https://www.avast.com/antivirus
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
http://www.spatialys.com
