[gdal-dev] make install fails
Matthias Kuhn matthias at opengis.ch
Thu Mar 3 02:56:04 PST 2016
Thank you for the reply, Even
On 03/03/2016 11:49 AM, Even Rouault wrote:
> Le jeudi 03 mars 2016 11:31:52, Matthias Kuhn a écrit :
>> Hi,
>> I am trying to compile and install gdal in docker (ubuntu 12.04)
>> container with python3 and in a custom prefix (/home/travis/deps),
>> clang-3.6 is used. configure and make run fine, however, make install
>> fails:
>> /bin/bash -pthread -shared -Wl,-O1 -Wl,-Bsymbolic-functions
>> -Wl,-Bsymbolic-functions -Wl,-z,relro
>> build/temp.linux-x86_64-3.2/extensions/osr_wrap.o -L../../.libs -L../../
>> -L/usr/src/gdal-2.0.2/lib -lgdal -o
>> build/lib.linux-x86_64-3.2/osgeo/_osr.cpython-32mu.so
>> /bin/bash: -d: invalid option
>> error: command '/bin/bash' failed with exit status 1
>> Any idea what could be the cause for this? I am grateful for any hints!
> I suspect you need to have gcc installed since the Python bindings require it.
> I'm surprised that you didn't run into problems with the default make target
> in swig/python when compiling the bindings.
gcc is installed
gcc --version
gcc (Ubuntu/Linaro 4.6.4-1ubuntu1~12.04) 4.6.4
> You should go to swig/python and try "make" from there.
/usr/src/gdal-2.0.2/swig/python# make
make: Nothing to be done for `all'.
> Anyway "make install" of the Python bindings didn't honour the custom prefix in
> versions before trunk, so after fixing the above, it will try to install in
> /usr/local.
I don't mind switching to trunk, thanks for the hint!
Matthias
>> Thank you in advance,
>> Matthias
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
