[gdal-dev] Google Summer of Code
    Tanuj Kumar
    kmrtnjscnc at gmail.com
    Thu Mar 24 01:35:13 PDT 2016
Hello Dmitry,
I have made the necessary changes to libpng, you can check it here :
https://github.com/OSGeo/gdal/pull/110/files
I have finally been able to download the source properly, and then I ran
the PNG test.
Out of 14 tests, 1 failed. Here are the details:
  TEST: png_1 ... success
  TEST: png_2 ... success
  TEST: png_3 ... success
  TEST: png_4 ... success
  TEST: png_5 ... success
  TEST: png_6 ... success
  TEST: png_7 ... success
  TEST: png_8 ... success
  TEST: png_9 ... success
  TEST: png_10 ... success
  TEST: png_11 ... success
  TEST: png_12 ... success
  TEST: png_13 ... success
  TEST: png_14 ... None
fail
    line 317: failure
Test Script: png
Succeeded: 13
Failed:    1 (0 blew exceptions)
Skipped:   0
Expected fail:0
Duration:  0.04s
Found libgdal we are running against : /usr/local/lib/libgdal.so.20.0.2
I checked png.py, and test 14 is "Test support for nbits < 8".
Could you please advise me how to proceed now?
On Tue, Mar 22, 2016 at 2:07 AM, Tanuj Kumar <kmrtnjscnc at gmail.com> wrote:
> Hello Dmitry,
> Thank you for your feedback. I will look into all the files in libpng once
> again.
> About the python support - I think I found the problem, I guess that when
> I was downloading the source, due to poor net at the time a few files
> didn't get through. So now I'm downloading again, and I'll let you know if
> there are any more issues.
> Cheers
> Tanuj
> On Tue, Mar 22, 2016 at 1:33 AM, Dmitry Baryshnikov <bishop.dev at gmail.com>
> wrote:
>> Hi Tanuj,
>> I compare current libpng folder and previous one:
>> 1. You include a lot of files needed to build standalone library, but not
>> need in GDAL sources tree (like configure, CMakeLists.txt, etc.).
>> 2. The makefile.vc removed and it seems to me the windows build will
>> fail in that case.
>> 3. There was a libpng_gdal.patch file, are you sure that this file is not
>> necessary?
>> 4. You included several files need for libpng unit testing, but not
>> needed by GDAL. According to GNUMakefile in png folder, it get all *.c
>> files from libpng folder, so we need minimum set of *.c and *.h files there
>> (but enough for VC building too).
>> About python support - do you did sudo make install (Linux)? The only
>> building is not enough to have python bindings work (there is a tick with
>> PYTHONPATH, but not sure that it works.
>> Best regards,
>>     Dmitry
>> 20.03.2016 10:15, Tanuj Kumar пишет:
>> Hello Dmitry,
>> Sorry for the long delay, my exams had the better of me, but now they're
>> over :) .
>> I have updated libpng 1.6.21 and i have created a pull request after
>> removing files from original libpng 1.6.21 that I think would not be
>> required as a library in GDAL.
>> All test on travis have been passed, and you can see the pull request
>> here : https://github.com/OSGeo/gdal/pull/108
>> As for building on desktop, I configured with python, but the same issue
>> of "ImportError: No module named osgeo persists". I am trying to understand
>> why this is happening, and am working out how to get rid of this problem by
>> reading GDAL wiki.
>> Cheers
>> Tanuj
>> On Tue, Mar 15, 2016 at 1:24 AM, Dmitry Baryshnikov <bishop.dev at gmail.com
>> > wrote:
>>> Hi Tanuj,
>>> The error: ImportError: No module named osgeo
>>> is because you build gdal without python support (you need python with
>>> developers headers).
>>> On Linux Linux this is done via such command:
>>> ./configure --with-python ... <other config options>
>>> On Windows it depends how you build. On Windows I launch separate tests
>>> successfully but never try the whole tests (run_all.py).
>>> Best regards,
>>>     Dmitry
>>> 14.03.2016 19:11, Tanuj Kumar пишет:
>>> Hello Dmitry,
>>> I was reading up on the gdalautotest wiki(
>>> <http://trac.osgeo.org/gdal/wiki/TestingNotes>
>>> http://trac.osgeo.org/gdal/wiki/TestingNotes), and it says, "After
>>> building with either the old or new generation python bindings, and
>>> installing them (or adding them to your path from the build tree)..."
>>> I could not understand what that means. I guess this is important
>>> because when I tried the commands given on that page, I got the following
>>> error :
>>> File "./run_all.py", line 37, in <module>
>>> import gdaltest
>>> File"pymod/gdaltest.py", line 37, in <module>
>>> from osgeo import gdal
>>> Now, as far as I could understand, it is importing a file called
>>> "gdal.py" from a folder called osgeo. I searched for it, and got its path
>>> as "gdal/swig/python/osgeo, whereas the autotest folder is separate.
>>> So my guess is I have to somehow specify the path of "gdal.py"
>>> Could you or anyone please guide me on how to proceed with this?
>>> Thanks
>>> Tanuj
>>> On Sat, Mar 12, 2016 at 11:00 PM, Tanuj Kumar < <kmrtnjscnc at gmail.com>
>>>> Alright, thank you very much, I'll get to work on it!
>>>> On Sat, Mar 12, 2016 at 10:47 PM, Dmitry Baryshnikov <
>>>> <bishop.dev at gmail.com>bishop.dev at gmail.com> wrote:
>>>>> Hi Tanuj,
>>>>> I wrote a big letter to the list. There is some answers there. Also I
>>>>> add comments below.
>>>>> Best regards,
>>>>>     Dmitry
>>>>> 12.03.2016 10:36, Tanuj Kumar пишет:
>>>>> Sorry for replying so late, got caught up in an exam :)
>>>>> I replaced libpng folder of gdal (frmts/png/libpng) with libpng
>>>>> 1.6.21. And then used ./configure and make install on this test version of
>>>>> gdal, which installed successfully. I used gdalinfo on a png file provided
>>>>> with the libpng 1.6.21 source, to check if it was OK, and it successfully
>>>>> gave the png file details.
>>>>> Is that enough to check the build on the computer?
>>>>> No, the autotests must be passed.
>>>>> I have also tested the gdal library with libpng 1.6.21 on Travis, and
>>>>> the build succeeded.
>>>>> <https://travis-ci.org/Raeburn1687/gdal/builds/115487530>
>>>>> Would all that be enough to check whether the update was succesful?
>>>>> I expected that travis from main gdal repo checked your PR.
>>>>> PS - Although I have copied the files from libpng 1.6.21 source to the
>>>>> gdal libpng folder, how would I know if any of those files are not required
>>>>> for gdal?
>>>>> You need to see the previous version. Some files not needed (i.e.
>>>>> configures and so on, which already comes from gdal, but legal notice must
>>>>> be present (license, autors, etc.) ). Don't hesitate to ask in list.
>>>>> Thank you
>>>>> Tanuj
>>>>> On Thu, Mar 10, 2016 at 2:07 PM, Dmitry Baryshnikov <
>>>>>> Hi Tanuj,
>>>>>> 09.03.2016 13:17, Tanuj Kumar пишет:
>>>>>> Yes, I have looked at the ideas list, and I am currently reading up
>>>>>> on idea no. 16, which is, implementing support for the proposed standard
>>>>>> for incrementally parseable GeoJSON data.
>>>>>> Also, I was thinking that maybe I could work on ticket no 6294,
>>>>>> <https://trac.osgeo.org/gdal/ticket/6294>
>>>>>> after I've studied about the GSoC idea, which is not really a bug,
>>>>>> but an enhancement. But if there are any other tickets that you or anyone
>>>>>> else would like to recommend me to work on, I'd love to see them too!
>>>>>> I think this rather arguing ticket as the bool is not exist in plain
>>>>>> C, and duplication functions seems to me not good idea.
>>>>>> I think this ticket <https://trac.osgeo.org/gdal/ticket/6185>
>>>>>> https://trac.osgeo.org/gdal/ticket/6185 is good for: 1. building
>>>>>> GDAL, 2. Testing via TraviC on GitHub. By the way the libpng version is
>>>>>> 1.6.21 or maybe higher.
>>>>>> Anyhow, you have to try to build gdal and test it with autotests from
>>>>>> appropriate folder.
>>>>>> Now, about the GSoC idea, do I need to know JSON( or GeoJSON, for
>>>>>> that matter) to work on it? I only ask because the idea lists C/C++ as the
>>>>>> required skills, but I feel that maybe this work would involve knowing JSON
>>>>>> too...
>>>>>> Yes, certainly. But JSON are very simple. Also GeoJSON spec. can be
>>>>>> found here <http://geojson.org/>http://geojson.org/Thanks and
>>>>>> regards,
>>>>>> Tanuj
>>>>>> On Wed, Mar 9, 2016 at 2:58 PM, Dmitry Baryshnikov <
>>>>>>> Hi, Tanuj
>>>>>>> I'll look for opened tickets for you, or maybe others can recommend
>>>>>>> some for you.
>>>>>>> By the way, do you see the idea list (
>>>>>>> <https://trac.osgeo.org/gdal/wiki/SummerOfCode#a2016IdeasList>
>>>>>>> https://trac.osgeo.org/gdal/wiki/SummerOfCode#a2016IdeasList)?
>>>>>>> The ideas are not ranked yet - the numbers in the list - are only in
>>>>>>> order.
>>>>>>> This is a task for us to rank the ideas.
>>>>>>> But, have you some preferable idea (or ideas) for GSoC from this
>>>>>>> list or maybe you have got own?
>>>>>>> Best regards,
>>>>>>>     Dmitry
>>>>>>> 04.03.2016 16:11, Tanuj Kumar пишет:
>>>>>>> Hello,
>>>>>>> I am interested in applying for GSoC this year. Currently, I am
>>>>>>> reading up on the GDAL Summer of Code ideas list. I know C++ and C, and I
>>>>>>> have some experience on working on linux.
>>>>>>> Could the mentors please recommend a bug for me to work on, I'd
>>>>>>> really love to start off as soon as possible!
>>>>>>> Thank you,
>>>>>>> Tanuj Kumar
>>>>>>> Birla institute of Technology and Science
>>>>>>> Pilani, Rajasthan,
>>>>>>> India
>>>>>>> _______________________________________________
>>>>>>> gdal-dev mailing listgdal-dev at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/gdal-dev
>>>>>>> <gdal-dev at lists.osgeo.org>gdal-dev at lists.osgeo.org
>>>>>>> <http://lists.osgeo.org/mailman/listinfo/gdal-dev>
>>>>>> Best regards,
>>>>>>     Dmitry
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160324/37e3efad/attachment-0001.html>
