[gdal-dev] Starting a discussion on style and coding guidelines
Joaquim Luis jluis at ualg.pt
Fri May 6 07:20:37 PDT 2016
On Fri, 06 May 2016 15:00:07 +0100, Even Rouault
<even.rouault at spatialys.com> wrote:
>> - ECW SDK 5.2.1: available for VS2010, VS2012, VS2013
> I got information that the next SDK 5.3 should support VS2012, 2013 and
> 2015
> (so no more 2010) + GCC 5
And one can also build SDK 3.3 with all of those compilers (I did).
