[gdal-dev] Creating a GeoPackage with multiple tile raster source in gdal 2.1.0
Gane R gane.prog at gmail.com
Tue May 17 08:08:32 PDT 2016
Hi all,
I am using a pre-build version of gdal 2.1.0. I am able to create GeoTIFF
to GeoPackage using gdal_translate.
I see from the Geopackage specification I understand that Geopackage can
have multiple tile sources, If so
Q1: How to I add a tilesource to an exisiting geopackage from a GeoTIFF ?
any command line or any workflow sequence will be of great help.
Q2: If a geopackage has multiple Geopackage tile raster, If I wish to
convert any one to a geotiff how will I do ? Should I used OGR Select layer
or how ??
Thanks
Gane
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20160517/e8298945/attachment.html>
