[gdal-dev] Why are fields required in osmconf.ini file?
Djordje Spasic issworld2000 at yahoo.com
Fri Nov 18 07:25:31 PST 2016
Thank you Jukka.
Can the command you gave me:
ogr2ogr -f PostgreSQL "PG:dbname=osm" test.pbf -lco
COLUMN_TYPES=all_tags=hstore
be edited so that the output file is a .shp instead of .pbf?
"C:\gdal\ogr2ogr.exe" --config OSM_USE_CUSTOM_INDEXING NO -skipfailures -f "ESRI Shapefile" -f PostgreSQL "PG:dbname=osm" "C:\output.osm" -lco COLUMN_TYPES=all_tags=hstore
I am converting an .osm to .shp files.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20161118/63a129c2/attachment.html>
