[gdal-dev] Nodata values in RGB orthoimages (GeoTiff)
Even Rouault even.rouault at spatialys.com
Tue Nov 22 03:49:49 PST 2016
On mardi 22 novembre 2016 09:08:02 CET Neumann, Andreas wrote:
> Hi,
> Is there a way to store nodata values in GeoTiffs that don't match an
> RGB value? I used either white or black as nodata values, but in some
> rare cases these black or white pixel values do appear as valid data in
> the image.
> How can I properly store nodata values in RGB Orthoimages in GeoTiffs
> where the borders aren't purely rectangular?
> Would I have to use a hard mask for regions where there is no data, or
> is there a trick with an alpha band?
There are several potential issues:
* by default, nodata is dealt band-per-band. So if you have nodata at 255, but
a RGB triplet is (255,0,0), then it will be considered as nodata for the red
band, but valid for the green and blue bands. To avoid that you can set the
"NODATA_VALUES=255 255 55" metadata item to indicate that the 3 components
must match at the same time. For example with:
gdal_edit.py foo.tif -mo "NODATA_VALUES=255 255 55" -unsetnodata
Then gdaladdo should properly take that into account
* If you indeed have valid pixels at (255,255,255) in the middle of the
raster, then the above is not sufficient, and you need to create a dedicated
alpha channel or mask band that gdaladdo will honour as well.
You can do that with nearblack -white -setalpha/-setmask
Even
http://www.spatialys.com
