[gdal-dev] Nodata values in RGB orthoimages (GeoTiff)
    Neumann, Andreas
    a.neumann at carto.net
    Tue Nov 22 00:08:02 PST 2016
Is there a way to store nodata values in GeoTiffs that don't match an
RGB value? I used either white or black as nodata values, but in some
rare cases these black or white pixel values do appear as valid data in
the image.
How can I properly store nodata values in RGB Orthoimages in GeoTiffs
where the borders aren't purely rectangular?
Would I have to use a hard mask for regions where there is no data, or
is there a trick with an alpha band?
Thank you for any hints and greetings,
Andreas
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20161122/e5b81e83/attachment.html>
