[gdal-dev] GDAL Errors while building PostGIS extension?
Greg Troxel gdt at lexort.com
Fri Oct 28 07:35:28 PDT 2016
sablok <sablok at amazon.com> writes:
> Indeed that is the problem, I am using GCC 4.9.2 to build postgis and its
> dependencies, however the version of libz that is present inside the
> postgresql's lib directory has been compiled with GCC 4.9.3 version. Can you
> let me know is that the real problem here and what are the consequences that
> this process entails of compiling against a library with different versions
> of GCC?
4.9.2 vs 4.9.3 is probably not it.
1) You still have not explained everythihng you are doing.
2) I think you need help about building software in general, not help
about gdal.  Perhaps you should try coworkers since you seem to be at a
large company.
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20161028/4ffef999/attachment.sig>
