[gdal-dev] does gdalwarp recognize/handle NODATA_VALUES metadata?
Even Rouault even.rouault at spatialys.com
Wed Sep 21 08:30:47 PDT 2016
Le mercredi 21 septembre 2016 16:57:46, Daniele Romagnoli a écrit :
> Hi list.
> I'm using GDAL 2.1.1 and I have a question (I didn't checked yet with a
> test to confirm or not the result).
> In case I configure a GeoTIFF dataset with NODATA_VALUES=0 0 0 in order to
> specify an RGB(0,0,0) triplet as nodata, would the gdalwarp utility handle
> it?
Hi Daniele,
Yep, tested at
https://github.com/OSGeo/gdal/blob/trunk/autotest/utilities/test_gdalwarp.py#L1392
Even
http://www.spatialys.com
