[gdal-dev] Fwd: [Projects] please create a new project flyer for your project with the new branding till FOSS4G Boston
Luca Delucchi lucadeluge at gmail.com
Tue Aug 8 01:09:38 PDT 2017
On 5 August 2017 at 23:13, Jeff McKenna <jmckenna at gatewaygeomatics.com> wrote:
> Luca: I have taken Even's feedback and made some more text changes, and also
> added a hillshade DEM (of Frank's home area in Canada) created through GDAL
> 2.2.1 on my machine.  It creates a big SVG now, but you/designer can decide
> to keep that image or not. http://www.gatewaygeomatics.com/dl/gdal_a4.svg
Thanks Jeff, good job.
> PS. I created it using LibreOffice!
It create strange SVG file completely different from Inkscape, I'm
going to replace text in the old SVG, so it should be simpler to
modify...
> -jeff
ciao
Luca
www.lucadelu.org
