[gdal-dev] Call for discussion on RFC68: C++11 compilation mode
Even Rouault even.rouault at spatialys.com
Mon Aug 14 10:02:15 PDT 2017
Hi Tamas,
Unless I'm mistaken your gisinternals.com builds don't include MSVC 2015 currently. Right ?
Do you have any plans to do so ? Currently the GDAL AppVeyor target uses SDKSs from
gisinternals to do builds with a number of third-party libraries.
Even
> This is a call for discussion on RFC68 to set C++11 to be the minimum C++
> language version for GDAL trunk.  I've drafted the RFC based on work by
> Mateusz.
>   https://trac.osgeo.org/gdal/wiki/rfc68_cplusplus11
> There was initial discussions back in January of this year:
>   https://lists.osgeo.org/pipermail/gdal-dev/2017-January/thread.html#45786
> Cheers,
> -kurt
> Engineer at Google
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170814/5e22acf0/attachment-0001.html>
