[gdal-dev] Geopackage raster and empty tile matrix
Andrea Aime andrea.aime at geo-solutions.it
Sun Aug 27 03:06:39 PDT 2017
I've exported a TIFF to geopackage raster, and noticed that while the
exported data only cover
zoom level 7, the tile matrix definition ranges from 0 to 7.
>From the reader point of view, it seems that in order to get the
effectively populated tile
matrix levels one would have to run a select distinct on the zoom level in
the tile table,
which seems rather inefficient.
I checked the spec and while it demands a tile matrix spec for populated
levels, it does not
seem to require omitting it for non populated levels. Can you confirm?
I think I'm seeing in the code a check verifying that indeed at least one
tile is present before
listing a particular zoom level:
// In read-only mode, only lists non empty zoom levels
    else if( !bUpdate )
        osSQL += CPLSPrintf(" AND EXISTS(SELECT 1 FROM %s WHERE zoom_level
= tm.zoom_level LIMIT 1)",
                            osQuotedTableName.c_str());
Cheers
Andrea
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39  339 8844549
http://www.geo-solutions.it
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170827/335d4e12/attachment.html>
