[gdal-dev] Geopackage raster and empty tile matrix
Even Rouault even.rouault at spatialys.com
Sun Aug 27 03:47:57 PDT 2017
Hi Andrea,
> Hi,
> I've exported a TIFF to geopackage raster, and noticed that while the
> exported data only cover
> zoom level 7, the tile matrix definition ranges from 0 to 7.
> From the reader point of view, it seems that in order to get the
> effectively populated tile
> matrix levels one would have to run a select distinct on the zoom level in
> the tile table,
> which seems rather inefficient.
> I checked the spec and while it demands a tile matrix spec for populated
> levels, it does not
> seem to require omitting it for non populated levels. Can you confirm?
Yes that's my understanding too that gpkg_tile_matrix can be instanciated at zoom levels for
which there is actually no tile in the pyramid table. I guess I did this choice betcause I wasn't
sure how to interpret the requirement for consecutive zoom levels differing by a factor of 2,
and thus chose to pre-create all zoom levels from level 0 to level N. This is also slightly more
convenient in update mode if you want to add tiles at low zoom levels: you just have to insert
them into the pyramid table.
> I think I'm seeing in the code a check verifying that indeed at least one
> tile is present before
> listing a particular zoom level:
> // In read-only mode, only lists non empty zoom levels
>     else if( !bUpdate )
>         osSQL += CPLSPrintf(" AND EXISTS(SELECT 1 FROM %s WHERE zoom_level
> = tm.zoom_level LIMIT 1)",
>                             osQuotedTableName.c_str());
Yes that's the request to find which zoom levels are actually populated so as to find the
highest zoom level (the base level used to compute the raster dimensions) and the populated
overviews. I would expect this request to be not that inefficient since the pyramid table has
an index on (zoom_level, tile_column, tile_row), thus finding if at least one tile exists at a
zoom level should only involve looking at the index.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170827/3c2de48c/attachment-0001.html>
