[gdal-dev] vrt: prevent opening all source files on open?
Vincent Schut schut at satelligence.com
Mon Aug 28 03:20:12 PDT 2017
Is there a way (or: what are the prerequisites) to avoid gdal opening
all source files from a vrt on opening the vrt?
Context: I have created a large vrt, referencing many tif files. Both
the vrt and tifs are remote (using /vsigs/). It works, but opening (e.g.
running gdalinfo) is very slow.
I have a comparable vrt where the main difference is that it references
.hgt files instead of tifs. Running gdalinfo on this vrt is almost
instantaneous.
As there are no other significant differences otherwise, I wonder if
this is because if the vrt machinery encounters a tif, it starts to
check if there are any accompanying overviews (or other important
metadata), while it does not do that for a .hgt file? Or is there a
different reason? And how can I prevent this (without, preferably,
changing to a different source file format)?
Thanks,
Vincent.
