[gdal-dev] Shapefile with one feature and many incrementally-added vertices is huge
Stefan Keller sfkeller at gmail.com
Thu Jan 19 06:31:07 PST 2017
@Even: Great work!
@Nik: I would avoid using Shapefile in the first place.
IMHO there are other formats which hare better suited for this use
case, like e.g. GeoPackage.
:Stefan
2017-01-19 14:38 GMT+01:00 Even Rouault <even.rouault at spatialys.com>:
>> In that
>> particular case the writer could realize that we are editing the last
>> geometry, so it could safely overwrite in place, but this isn't
>> implemented
>> yet.
> Well, that was rather simple to implement. So fixed per
> https://trac.osgeo.org/gdal/ticket/6787
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
