[gdal-dev] WFS-T using OGR
    Ahmed Tolba
    Ahmed.Tolba at schiebel.net
    Fri Jan 27 03:30:21 PST 2017
This is the schema of that layer:
<FeatureType><Name>tows:poi_ais</Name><Title>AIS POI</Title><SRS>EPSG:4326</SRS><LatLongBoundingBox minx="48.019324" miny="11.762924" maxx="48.031035" maxy="11.808243"/></FeatureType><FeatureType>
From: Even Rouault [mailto:even.rouault at spatialys.com]
Sent: Friday, January 27, 2017 12:22 PM
To: Ahmed Tolba
Cc: gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
Subject: Re: [gdal-dev] WFS-T using OGR
On vendredi 27 janvier 2017 10:59:21 CET Ahmed Tolba wrote:
> Hi
> Thanks for your answer.
> I tried to do what you suggested, but I get " Can not insert the feature,
> because we didn't manage to parse the .XSD schema "
As the message suggests, the OGR WFS client didn't manage to get or correctly parse the schema for the layer. This is a bit surprising as TinyOWS should generate simple enough schemas for OGR to understand them. Difficult to know what happens without being able to reproduce on my side.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170127/e04d8fc0/attachment.html>
