[gdal-dev] DataSource/Dataset using gdal.Grid()
Even Rouault even.rouault at spatialys.com
Thu Jun 1 12:27:06 PDT 2017
> Thanks Even, for the fast response. You mention the OGRDataSource as
legacy.
> I wasn't aware of that fact. Is there anything important to know about
> that, because I would need to port quite some code to use the
GDALDataset.
Have a look at https://svn.osgeo.org/gdal/trunk/gdal/
MIGRATION_GUIDE.TXT
and particularly
http://trac.osgeo.org/gdal/wiki/rfc46_gdal_ogr_unification
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170601/aa4a5486/attachment.html>
