[gdal-dev] libcurl and the certificates and Windows
Joaquim Luis jluis at ualg.pt
Mon Jun 5 15:02:54 PDT 2017
Even ,
I think you may be interested to see the all extend of
https://github.com/curl/curl/issues/1538 Not friendliest place to report
(possible) issues.
Joaquim
> On lundi 5 juin 2017 19:07:24 CEST Vautour, André (INT) wrote:
>> I'd like to add that I think an option like GDAL_HTTP_CA_CERT_FILE or
>> GDAL_HTTP_CA_CERT_PATH would be useful to have.
> See http://gdal.org/cpl__http_8h.html#aee8368b7821300f4b81ef4da8a9c6a29
> CAINFO=/path/to/bundle.crt. This is path to Certificate Authority (CA)
> bundle file. By default, it will be looked in a system location. If the
> CAINFO options is >not defined, GDAL will also look if the
> CURL_CA_BUNDLE environment variable is defined to use it as the CAINFO
> value, and as a fallback to the >SSL_CERT_FILE environment variable.
> (GDAL >= 2.1.3)
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170605/dc3be9e1/attachment-0001.html>
