[gdal-dev] libcurl and the certificates and Windows
Even Rouault even.rouault at spatialys.com
Mon Jun 5 16:07:10 PDT 2017
On lundi 5 juin 2017 23:02:54 CEST Joaquim Luis wrote:
> https://github.com/curl/curl/issues/1538
Hopefully https://trac.osgeo.org/gdal/changeset/38903 should improve
the situation a bit (note: completely untested), provided curl-ca-bundle.crt
is in one of the searched paths. Note: as far as I can see, this is not the case
in gisinternals since it is not in the path where GDAL binaries are...
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170606/47bbf2c9/attachment.html>
