[gdal-dev] compiling gdal with esri file gdb
Richard Greenwood richard.greenwood at gmail.com
Sat Mar 11 08:28:40 PST 2017
Many thanks for your help and patience. Using ogr2ogr 2.2 with the
OpenFileGDB driver reads ESRI file GDBs that contain curves. When
converting to a shapefile curves are converted to a series of short
tangents. When converting to postgis the curves appear to be preserved as
curves. Very nice!
Rich
On Sat, Mar 11, 2017 at 8:21 AM, Richard Greenwood <
richard.greenwood at gmail.com> wrote:
> On Sat, Mar 11, 2017 at 7:20 AM, Even Rouault <even.rouault at spatialys.com>
> wrote:
>> On samedi 11 mars 2017 07:15:27 CET Richard Greenwood wrote:
>> > On Sat, Mar 11, 2017 at 1:34 AM, Damian Dixon <damian.dixon at gmail.com>
>> > wrote:
>> > > Have you tried OpenFileGDB? (you will need GDAL 2.2 or newer for curve
>> > > geometries).
>> > I would prefer OpenFileGDB but how do I enable it?
>> It is a built-in driver. No option.
>> --with-fgdb is when you want to enable the FileGDB driver that relies on
>> the ESRI SDK
> Thanks! When I did ./configure and saw "FGDB support: no"  I thought that
> I had to set --with-fgdb.
> Richard W. Greenwood, PLS
> www.greenwoodmap.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170311/fd401f78/attachment.html>
