[gdal-dev] GDAL make error
Even Rouault even.rouault at spatialys.com
Fri Nov 10 03:35:54 PST 2017
> Why would extra options be enabled when we haven't made any changes
to the
> makefile? And are these extra options likely to be the failure in building
> libgdal.so?
Jon,
Make sure you do a "make clean" as the configuration has changed
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20171110/f40bf7e0/attachment.html>
