[gdal-dev] Cannot build for iOS due to GUInt64 error
Nik Sands nik at nixanz.com
Fri Nov 10 16:09:48 PST 2017
I’m attempting to build GDAL for the first time in a while, and this is the first time for GDAL 2.2.2.  I’ve getting the following error when building for iOS arm64 on Mac OS X:
geotiff.cpp:7653:13: error: unknown type name 'GUInt64'
    typedef GUInt64 WordType;
1 error generated.
make[2]: *** [../o/geotiff.lo] Error 1
make[1]: *** [gtiff-install-obj] Error 2
make: *** [frmts-target] Error 2
The relevant part of geotiff.cpp is:
#if SIZEOF_VOIDP == 8 || defined(__x86_64__)
    // We test __x86_64__ for x32 arch where SIZEOF_VOIDP == 4
#else
    typedef unsigned int WordType;
#endif
Should I be adding some exception condition into the ‘if’ part in order to get it to use unsigned int instead of GUInt64?  Or is there some other way that this should be handled for iOS arm64 when building on Mac OS X?
Cheers,
Nik.
NIK SANDS
Line Tamer | Time Traveller | Space Cadet
