[gdal-dev] Vertical datum conversion for SRTM data
Even Rouault even.rouault at spatialys.com
Tue Nov 21 03:18:22 PST 2017
On mardi 21 novembre 2017 10:25:42 CET Nikos Alexandris wrote:
> Dear list, can GDAL handle the following exercise?
> Of interest is the Mean Sea Level, based on NASA’s SRTM. I am new in this
> topic. Is the following equation correct?
> SRTM(MSL) = SRTM(WGS84) - MSL(WGS84) [*]
> Is it “correct” to recommend the https://hydrosheds.cr.usgs.gov/ data
> set for Mean Sea Level related studies? I refer specifically to i) 5.1
> Void-filled digital elevation model  and ii) 5.2 Hydrologically conditioned
> elevation [**]
Not completely sure this answers your questions ,but this is related.
Quoting end of http://www.gdal.org/gdalwarp.html:
    (GDAL >= 2.2) To transform a DEM from geoid elevations (using EGM96) to WGS84 ellipsoidal heights:
gdalwarp -overwrite in_dem.tif out_dem.tif -s_srs EPSG:4326+5773 -t_srs EPSG:4979
This assumes the egm96_15.gtx grid is in the proj.4 resource directory.
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20171121/e63db7c7/attachment.html>
