[gdal-dev] Vertical datum conversion for SRTM data
Michael Smith michael.smith.erdc at gmail.com
Tue Nov 21 03:27:41 PST 2017
Egm96 grid shift file available from http://download.osgeo.org/proj/vdatum/egm96_15/egm96_15.gtx
Mike
Michael Smith
Remote Sensing/GIS Center
US Army Corps of Engineers
From: gdal-dev <gdal-dev-bounces at lists.osgeo.org> on behalf of Even Rouault <even.rouault at spatialys.com>
Date: Tuesday, November 21, 2017 at 6:18 AM
To: <gdal-dev at lists.osgeo.org>
Subject: Re: [gdal-dev] Vertical datum conversion for SRTM data
On mardi 21 novembre 2017 10:25:42 CET Nikos Alexandris wrote:
> Dear list, can GDAL handle the following exercise?
> Of interest is the Mean Sea Level, based on NASA’s SRTM. I am new in this
> topic. Is the following equation correct?
> SRTM(MSL) = SRTM(WGS84) - MSL(WGS84) [*]
> Is it “correct” to recommend the https://hydrosheds.cr.usgs.gov/ data
> set for Mean Sea Level related studies? I refer specifically to i) 5.1
> Void-filled digital elevation model and ii) 5.2 Hydrologically conditioned
> elevation [**]
Not completely sure this answers your questions ,but this is related.
Quoting end of http://www.gdal.org/gdalwarp.html:
(GDAL >= 2.2) To transform a DEM from geoid elevations (using EGM96) to WGS84 ellipsoidal heights:
gdalwarp -overwrite in_dem.tif out_dem.tif -s_srs EPSG:4326+5773 -t_srs EPSG:4979
This assumes the egm96_15.gtx grid is in the proj.4 resource directory.
http://www.spatialys.com
_______________________________________________ gdal-dev mailing list gdal-dev at lists.osgeo.org https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20171121/f5fd2b0b/attachment-0001.html>
