[gdal-dev] pass gdal dataset as an argument from Python to C
Ari Jolma ari.jolma at gmail.com
Tue Nov 28 00:02:10 PST 2017
Sean Gillies kirjoitti 27.11.2017 klo 20:46:
> I believe it's possible, yes, but it will be challenging. I'm not
> aware of anybody else doing this.
I'm doing it but in the Perl side. It's not impossible but Swig does
wrap the C pointers quite deep into the Perl object (it must be similar
in the Python Swig), so it needs a bit of research. However, I think it
is a quite stable way Swig does it and it's a matter of making a typemap
or a small function.
I think it is quite an important way to build extensions or link
systems. In my case I needed a system computing a raster dataset (band)
from other bands using a Bayesian network. I had built a Perl interface
to a proprietary Bayesian network engine, and thus I needed only the the
linkage code, which I built and is this:
https://github.com/ajolma/Geo-GDAL-Bayes-Hugin
See the typemap file for an example of a typemap (GDAL Band Perl object
to a C GDALBandH pointer).
Ari
> In
> https://github.com/OSGeo/gdal/blob/trunk/gdal/swig/python/extensions/gdal_wrap.cpp
> you can see examples of C++ functions that access the GDAL objects
> referenced by Python objects. This isn't a stable public API by any
> means, and therefore I hesitate to recommend it. Maybe Even would be
> able to comment more on how much support there is for the
> SWIG-generated C++ Python classes.
> I presume you've already tried writing "_my_module" in Python and
> found it to be too slow?
> Good luck!
> On Mon, Nov 27, 2017 at 9:34 AM, Shawn Gong <SGONG at mdacorporation.com
> <mailto:SGONG at mdacorporation.com>> wrote:
>     Thank you Sean.
>     What I want to do is to compile C/C++ code into "_my_c_module.pyd"
>     and then to be called by Python. The Python code passes an
>     argument to C/C++.
>     I did previously by passing a file name (str) or a numpy array as
>     argument to C/C++, and it is all good.
>     This time I want to pass a gdal dataset as an argument:
>     in Python:
>         from osgeo import gdal
>         import _my_c_module
>         ds=gdal.Open('my_filename")
>         result = _my_c_module.function1(ds)
>     is this possible? If yes, how?
>     Shawn
>     *From:* Sean Gillies [sean at mapbox.com <mailto:sean at mapbox.com>]
>     *Sent:* November-27-17 11:09 AM
>     *To:* Shawn Gong
>     *Cc:* gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
>     *Subject:* Re: [gdal-dev] pass gdal dataset as an argument from
>     Python to C
>     Shawn,
>     PyObject and GDALDatasetH are incompatible types and you can't
>     pass the former to a function that expects the latter. I'm
>     surprised your program can compile with these incompatible types.
>     Do you mean for your module to extend GDAL's Python bindings? If
>     you look inside the C code of GDAL's Python bindings you may be
>     able to see how to get the GDALDatasetH associated with a Python
>     dataset object.
>     Hope this helps,
>     On Thu, Nov 23, 2017 at 1:25 PM, Shawn Gong
>     <SGONG at mdacorporation.com <mailto:SGONG at mdacorporation.com>> wrote:
>         Hi list,
>         Has anyone done this before?
>         I try to pass a gdal dataset as an argument from Python to C.
>         in my C code, I have
>         PyObject* py_my_func(PyObject *self, PyObject *args)
>             PyObject *poDataset;
>            if(!PyArg_ParseTuple(args, "Odd", &poDataset, &a1, &a2))
>             return NULL;
>           my_func(poDataset, a1, a2);
>         void my_func(GDALDatasetH hDataset, double a1, double a2)
>         Python crashed and hDataset was NULL
>         Is it possible to do or I did something wrong?
>         BTW, I have passed either a filename or a gdal array as an
>         argument from Python to C, with success.
>         Thanks,
>         Shawn
>         _______________________________________________
>         gdal-dev mailing list
>         https://lists.osgeo.org/mailman/listinfo/gdal-dev
>         <https://lists.osgeo.org/mailman/listinfo/gdal-dev>
>     Sean Gillies
> Sean Gillies
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20171128/44373d26/attachment-0001.html>
