[gdal-dev] GDAL Cubic Interpolation
Joaquim Luis jluis at ualg.pt
Mon Oct 9 09:32:37 PDT 2017
Alternatively,  use GMT's grdsample with -fg option to force the knowledge
(if it's not already in the file) that the Earth is round.
http://gmt.soest.hawaii.edu/doc/5.4.2/grdsample.html
> Harvey,
>> I subsampled a GLOBE image of elevation data by a subsampling factor of
>> 12
>> to a resolution of 0.1 deg x 0.1 deg on integer multiples of 0.1 deg.
>> The
>> original GLOBE image is: Latitude from +90-1/240 deg to -90+1/240 deg in
>> 1/120 deg steps, and Longitude from -180+1/240 deg to +180-1/240 deg in
>> 1/120 deg steps.
>> I understand that the cubic interpolation method in gdalwarp accounts
>> for
>> the subsampling factor, so 48x48 adjacent pixels influence the target
>> pixel
>> for a subsampling factor of 12.
>> Does gdalwarp assume the original image is a sphere, where 48x48
>> adjacent
>> pixels influence all target pixels, or a rectangle, where a limited
>> number
>> of pixels influence the target pixels at the top, bottom, left, and
>> right
>> edges of the subsampled image?
> A rectangle, with fallback to bilinear resampling at edges
>> If gdalwarp assumes the original image is a
>> rectangle and uses a modified interpolation method at the four edges of
>> the
>> subsampled image, the modified method affects two rows and two columns
>> at
>> the top, bottom, left and right edges of the subsampled image. If
>> gdalwarp
>> assumes the original image is a rectangle, is there a command option so
>> gdalwarp considers spherical wrapping when interpolating?
> Nothing directly straightforward. Your below plan is the a reasonable
> solution.
>> Alternatively, I
>> assume I could augment the original GLOBE image with the appropriate
>> additional rows and columns on all four edges. If I did that, how do I
>> tell
>> gdalwarp the extent of the augmented input image?
> You'll have to recreate a properly referenced input image, for example
> with
> gdal_translate -ullr upperleftx upperlefty lowerleftx lowerlefty
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20171009/91193957/attachment.html>
